RC and MC Compatibility
TimCordrey
Would it be ok to put two RC 60’s and two MC 60’s together? Would sound be noticeably different to the average listener?
Answers
I wouldn't mix them together in the same system if starting from scratch. The RC has a metalized soft dome tweeter and the MC has a silk dome tweeter. That would be the main audible difference. Both types of tweeter can be aimed at the listening area. The MC is a better speaker line. The MC line is on a big discount on Crutchfield at the moment...
https://www.crutchfield.com/S-AN8QTWIxU5a/p_107MC60/Polk-Audio-MC60.html?XVINQ=GLX&awkw=75619605145&awat=pla&awnw=g&awcr=47439148225&awdv=c&awug=1027289&gclid=Cj0KCQiA0MD_BRCTARIsADXoopaHVrBZBNL_Wo9WQGhr1s6LAns1b_TiNkIOmCCCWIQKEmHCOtUW2l0aAiwREALw_wcB
If I already had a pair of one type installed I'd just build a system around that type. Doing in ceiling or in wall systems make it difficult to swap speakers later because of different speaker sizes so I say do it right the first time and match everything up from the beginning.
