Do I need hurricane nuts?
I tested my 7bs with peerless tweeters for air leaks by pushing in the PR and timing the driver back to its normal position. It is well over 15 seconds. I like the look of the hurricane bolts (Allen style head) but I think that installing it not necessary in my situation.... So any thoughts?
Thanks in advance.
Bob...
M7's 1982 Peerless tweeters
M5's X2 (1981 Peerless tweeters, 1988 with upgraded tweeters)
M4's X2 both with Peerless tweeters
M5Jr with SL1500 (in the garage, they sound great)
M4.6 series2 X2 with upgraded tweeters
SDA 2 with upgraded tweeters
Best Answer
    F1nut Posts: 52,027
    Answer ✓
    The purpose of installing hurricane nuts or Larry's rings is to clamp the driver baskets to the bezel better than the stock screws possibly could. This reduces basket vibration, which in turn cleans up the mid range and tightens the bass.
    The reason for your long push test result is the tight weave dust caps on the mid-drivers. Polk switched to dust caps with a more open weave later on.
Answers
  • I see... I was under the wrong impression on this.
    Thanks for clarification.
