Can't get optical plug to go into polk speaker
marylouberg
Overnight my polk came unplugged. I suspect my cats. I can't get the plug to go back in. HELP!
Answers
Are you able to see the cable end and port? It can only fit one way, on the off chance you're not aware.I disabled signatures.
