Carver AV505 good enough to power LSi7's???
MSkeezer
Hi all. I'm getting a couple pair of the 7's, and hopefully the LSi center speaker soon, and I'm wondering if this Carver amp will be good enough? I'll be using my DVD player for the decoding(had 5.1 analog outputs). Thanks.
Thomas
(EDIT) If the Carver won't work, can anyone recommend a low priced amp that will work?
Thomas
Post edited by MSkeezer on
If what you're asking is if the Carver will drive the 4 ohm load, i would imagine the answer to be yes. Is the the 5x80WPC model? What's that about 120WPC into 4 ohms? The 7's are only rated up to 150, so that will work fine.
I think the more important questions, do YOU like how it sounds? -
Yes, it's 5x80 watts.
