Procedure using test tones???
up2youjoe
up2youjoe Posts: 114
All,
Do I turn off all the other speakers except the sub when I run the tones in order to plot a graph?
No Kids Allowed
cold, heartless, clueless, greedy 'young professional'
Post edited by up2youjoe on
  • PolkWannabie
    PolkWannabie Posts: 2,763
    edited June 2004
    No. There should be a smooth transition from sub to speakers as frequency foes up.
  • racer4551
    racer4551 Posts: 373
    edited June 2004
    You could actually make a run with just the sub on,that would show you the curve of the subwoofer and how it interacts with the room,settings that have been made,and placement of the sub.Once you get a nice curve with the sub you can then add the mains and see how they affect the freq. curve.I have found out this is the best way to really dial in the sub and also will tell you alot about how each speaker affects the curve.
    *HT PRE-PRO*:Rotel rsp-1068, *AMP*:Rotel RMB 1095 *DVD PLAYER*:Denon 2200,*CD PLAYERS*,Arcam Alpha Mcd 6 disk carasel,Hughes Hdtv receiver, Hughes hdvr2,*MAINS*:Polk LSI 15'S, *CENTER*:Polk LSIC, *SIDE SURROUNDS*:Polk LSIFX,*REAR SURROUND*:Polk LSI 7'S,*SUB*:SVS PB2+*.MONITOR*:Mitsubishi ws48413 hdtv,Monsterpower hts2500X2,,Sony playstation2,Harmony sst-659 remote
