DB6502 Components Recommended Crossover Points?
Grogger
Hi There,
I have a DB6502 Component set with 6.5 woofers and tweeters. I'm setting it up as an active setup with a dsp. So the DSP will do the crossover job that the removed passives would have done.
I wondered if a someone could tell me the recommended crossover points for the woofers and the tweeters separately?
I understand polks website says the frequency response of the pair is something like 35 hz to 23khz. However, I'd like to know the recommended for each driver so I can dial in my tuning to get a nice full and warm sound from the components.
Grateful for any help with this!
I recommend sending an email to: kim.jasper@soundunited.com he has experience in Polk's car audio products.
Great, thanks Kenneth! will do.
You're welcome, enjoy!
I did some tuning updates over the weekend. My system now includes not only the DB6502 woofer and tweeter but a CDT ES02 mid range. My system sounds improved and cleaner with a crossover at 70hz and 4k for the woofer. 4k and 7k for the cdt mid. and 7k-20k for the tweeter. I used 24db slope linkwitz model crossover on my Audison Bit One DSP.
I received some crossover information about the db series polk speakers and components. I wanted to share for the benefit of others:
Here are all the dB series XO points and info so your team has them.
- dB 572: 1st order on both woofer and tweeter
- XO Acoustic frequency: 4.5kHz
- dB 652: 1st order on tweeter, 2nd order on driver
- dB 522: 1st order on both woofer and tweeter
- dB 402 and dB 462: 1st order on tweeter only, no XO on woofer
- dB 692: 1st order on tweeter, 2nd order on midrange, no XO on woofer
- XO Acoustic frequency between woofer and mid/twt = 4kHz
- dB 6502 and dB 5252: 2nd order on both woofer and tweeter
- XO Acoustic frequency: 5.5kHz
- Twt output levels: 0dB, +3dB, +6dB
- Poly switch to protect twt
