Polk Lsim 702 FX set up help
Dabutcher
Dabutcher Posts: 2,606
I just bought four speakers for side and rear surround duty. My room is approximately 12’ wide by 35’ long. I cannot mount rear wall because of long distance away. These are directional speakers. I was thinking two at sides in front of seating and two behind? But set up says four behind seating. Or should I just return or sell two and go 5.1?
Any and all help would be greatly appreciated.
  • Emlyn
    Emlyn Posts: 4,837
    I would try a pair on the back wall and run auto calibration as a test anyway. If that doesn’t work out with good results a 5.1 system would be fine.
  • If it were me I’d go one pair inline with the seating and one behind maybe 6ft.
  • shs
    shs Posts: 105
    Because of the angle with which the tweeter and midrange fire, the 702s should be placed either slightly ahead or slightly behind the MLP(s). I have mine slightly ahead of my MLP and it fires back at that location and the 2nd row behind the MLPs.
    SONY VPL-VW385ES, Da-Lite 92" 0.9 HD progressive 16x9 screen, Apple TV 4K, Oppo UDP 203, Anthem AVM 60, D-Sonic 4000 (800x3, 400x4) for bed layer, 2 Crown XLS 1002 (225x4) for Atmos; Speakers: Polk LSiM 705s, 703 front, 4 702F/X surround, 4 Polk TL3 (Atmos), Velodyne DD15 Subwoofer.
  • aboroth00
    aboroth00 Posts: 1,107
    Experiment! Put them on some boxes and try them out in different configurations. If you can go 7 ch then I'd advise doing it. Having the seamless transition from side to rear surround creates a more immersion.
    As a rule of thumb, you lose 6db when you double the distance.
    2Ch Tube Audio Convert
  • daboyz
    daboyz Posts: 5,207
    What if they were basically even or slightly behind the listening area? I've got Lsi7's there now.
  • shs
    shs Posts: 105
    The thing to remember about the app 702s is the the midrange and tweeter fire at a ~45° angle and so if they are even with the listening area then the listener will be 45° off-axis relative to the tweeter and all of the higher frequencies will be diminished. The LSi7s fire straight ahead so they are fine even with the listening area.
