Anyone using the IFI Blue Zen?
CH46E
CH46E Posts: 3,595
edited November 2020 in 2 Channel Audio
This looks very interesting as it would alow me to stream music to the new to me Anthem pre 2L.
https://www.amazon.com/dp/B07W5RB5GN/ref=cm_sw_r_cp_apa_fabc_lBERFb3ZAC362
  • rooftop59
    rooftop59 Posts: 8,120
    Looks cool! Never heard one. I do love my iFi nano iDSD DAC.
    You could also just get a squeezebox touch used for about the same price. It’s not Bluetooth but you can stream all your own flac files and tidal and Spotify and internet radio...
    Game Room 5.1.4:
    Bedroom 2.1
    msg Posts: 10,531
    I second this idea for a SBT instead, or something similar.
    I originally started off with some entry level type Bluetooth receivers, the IOGEAR TuneTap. I thought them the greatest thing at first, and they're still pretty good. It was the coolest thing back then getting my phone streaming to my stereo without wires, but then I got a Squeezebox and it was a lot nicer to just control the device over the mobile app instead of streaming media from it.
  • dpowell
    dpowell Posts: 3,081
    I use the Audioengine B1. https://www.amazon.com/Audioengine-B1-Premium-Bluetooth-Receiver/dp/B00MHTGZR4/ref=mp_s_a_1_3?dchild=1&keywords=audioengine+b1&qid=1605664548&sr=8-3
    Solid piece of gear with great range and consistent connections. A B comparison with the original source CD on my Sony ES player reveals the limitations of bluetooth but the Audioengine is a close runner up great for casual listening.
  • Gardenstater
    Gardenstater Posts: 4,855
    Both of my SBT's stopped working with TIDAL but still work fine with Qobuz. I'm wondering if they did something to stop SBT's from working when they partnered with certain companies (not Logitech) devices with the Connect rollout. I want to look into Audirvana and see if that might be a workaround instead of Logitech Media Server.
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
  • Both of my SBT's stopped working with TIDAL but still work fine with Qobuz. I'm wondering if they did something to stop SBT's from working when they partnered with certain companies (not Logitech) devices with the Connect rollout. I want to look into Audirvana and see if that might be a workaround instead of Logitech Media Server.
    Just to update in case anyone else was in the same boat, there is a new version of LMS (Logitech Media Server) that fixes the TIDAL problem, meaning that the music now plays again! As far as the issue of Hi Rez MQA selections not playing in higher resolutions than Redbook, that appears to still be the case, at least with my DAC which I have not updated the firmware in, to decode MQA. I will try that, but I think it must not be passing thru the MQA, and it is also not doing the initial partial unfold that the TIDAL desktop app does for us.
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
