FS: Panamax M5300-PM (Power Management)
Asking: $200, PayPal Friends/Family to avoid fees or you pay fees
Shipping: Actual cost w/insurance & signature…will be double boxed/safely packed
Includes: Original box, generic power cord, owner’s manual, rack mounting kit
Condition & Function: 10/10 (Can’t find a blemish)
Lives in a pet/smoke free home
Fine Print: Going w/the standard 100 posts and CP members in good standing. Anyone close to the minimums reach out…I’m a reasonable guy. Also, times are tough for some and music makes everything better. Folks I’ve “known” through the years on this forum…payment plan is always an option.
Purchased this from OneCall.com as an open box special, Dec 2010. Placed in storage when I moved to Germany, 2014, because it isn’t 220V compatible. Still in production and if you purchased new from Amazon, sells for $544.97. https://www.amazon.com/Panamax-M5300-PM-Outlet-Clean-Power/dp/B000SXWGAQ. I paid $337.92.
Solid performance while I used it and never took a power surge…ever. Turned it on, turned it off, admired the pretty blue display. Exactly what you hope it does. Associated gear formerly powered by it; 50” Panasonic Plasma TV, Parasound HCA-1500A, Rotel RB-985, Pioneer DV-79AVi, Oppo BDP-105.
I’d say this is great in a home theater environment but could work in a modest 2 channel setup if you want outlets and protection. The meters are really cool showing voltage and amps. Pics, following, show the power on my 2-channel line two days ago and mirrored my PS Audio P-15 PowerPlant. The display has several brightness settings and, unlike earlier versions, the display can be turned off in a dark (e.g. home theater) environment.
This isn’t what I’d call a serious power conditioner like a Niagra or PowerPlant but neither is the price. Provides power management and aids in notifying you in the event of under or overvoltage and will turn off the attached equipment if it encounters a surge.
Overview and Features from the Panamax website:
https://www.panamax.com/product/max-5300-power-management-2ru-11-outlets-M5300-PM
“Improves Picture and Sound Quality, Monitors Incoming Line Voltage, and Reduces Cross-Contamination Between Components.
Level 4 Power Cleaning and Filtration eliminates common symptoms of contaminated power (including loss of detail, pops, hisses, hums and visual artifacts) and allows your A/V equipment to perform up to its full capability.
Monitors Incoming Line Voltage and Provides a Visual Indication of Power Level
Panamax™ patent pending AVM circuitry continuously monitors the incoming power as displayed on the digital voltmeter. In case of an undervoltage or an overvoltage, a flashing red lightning bolt will be displayed in the voltmeter, and power to the connected equipment is automatically turned off if either of these conditions is detected. When voltage returns to a safe level, power to the equipment is automatically reconnected.
The M5300-PM is designed to provide noise isolation between 5 isolated outlet banks (including 1 bank with 2 high current outlets) so that any noise created by an A/V component cannot contaminate the power going to equipment plugged into another outlet bank.
  • Clean Power Level 4
  • Improves picture and sound quality by eliminating noise across the entire AC bandwidth. 40% more efficient at eliminating noise than Clean Power Level 3.
  • AVM (Automatic Voltage Monitoring)
  • Protects equipment against prolonged over/under voltages by disconnecting the power and reconnecting it when safe power returns.
  • High Current Outlets
  • 2 outlets for equipment with high power demands (Amps/Subwoofers).
  • USB Charger
  • 1 front panel 500mA USB charger. May not recognize all devices. Check manufactures power specifications of USB device.
  • Gaming LAN Port
  • Easy access to LAN port on front panel. Perfect for online gaming.
  • 5 Isolated Outlet Banks
  • Isolating outlet banks from one another prevents noise contamination between components.
  • 12 Volt Trigger
  • Allows source equipment to activate or deactivate the switched outlets on the M5300-PM.
  • Power Sequencing
  • Guards against blown fuses and potentially damaging speaker thump by automatically powering outlets on and off in sequence.
  • 11 Outlets
  • 5 Always On, 4 Switched, 2 Switched High Current."
Saved you some time looking for opinions from our very own forum:
https://forum.polkaudio.com/search?Search=panamax+5300
Please let me know if you have questions.
Thanks for looking,
John
Pics:
Speakers: Polk1.2tl's (Uber Mods) Pre/Amp/DAC: PS Audio PMG Signature Pre, BHK Signature 250, PMG Signature 512 Cables/IC's: MIT S1Bi-Wire/S1 Balanced +Avel Lindberg 1000VA "Dreadnought" Power Conditioner: PS Audio P15 Power Plant Power Cords: Core Power Technologies Gold, DH Labs Power Plus DIY w/Neotech NC-P301 & P311ends Streaming: Roon ROCK on wifi'd NUC, TP-Link WAP, & Uptone EtherREGEN, AfterDark, Emperor Double Crown Clock, Black Modernize LPS⟿Ω☯☥☮⟿🔊♩♪♫♬♩♪♫♬♩♪♫♬
    msg Posts: 10,595
    I like these for the power control with the switched outlets.
    Connect a pre/pro with 12v trigger to the Panamax, and the other outlets turn on and off with the pre/pro's state. Handy.
    Great price for this, especially given the condition and OE box.
  • Navy_Goat
    PM on its way.
    SDA SRS 2.3tl, SDA 1C, SDA 2B (TL mod), Reserve 200
  • JayCee
    JayCee Posts: 1,509
    Thanks to all that have replied.
    Current status:
    #1: @teekay0007
    #2: @Navy_Goat
    John
    Toolfan66 Posts: 18,334
    I will take it..
  • JayCee
    JayCee Posts: 1,509
    This is SOLD! Thank you and congratulations to @teekay0007.
