Nice Anthem Int 225 with very low hours pretty much new
For sale Anthem INT 225 in excellent condition and low hours on it. Pretty much new. Here is the story on this one. An older collector friend of mine bought this from a dealer locally almost 4 years ago and never opened it. Because that is um.. what collectors do. I opened it recently and have run it for a while now. Maybe 125 hours. It works exactly as it should and NO issues with the volume or any of that stuff. This is a later version so it has a basic remote. I have owned one before myself and can attest that it is a quality unit. This is a highly reviewed and respected integrated amp that puts out 225 w/ch into 8 ohms and 330 in 4 ohms. It features 7 inputs including a Balanced input and a front panel jack for an i pod. The 225 also has a very good MM phono section as well as bass and treble controls with defeat and a balance control. It has a headphone jack as well as a preamp out and sub out. The 225 is built like a tank and weighs over 40lbs. Includes, original double box, owners manual, power cord and the remote control. The Anthem is in excellent condition and everything works as it should. The reviews say it all. Asking $875 This is a very good price considering the situation
PHONO PREAMPLIFIER
The phono preamplifier is suitable for moving magnet and high-output moving coil cartrdiges
Input Impedance 47 kΩ
Input Capacitance 100 pF
Maximum Input 18 mV at 20 Hz, 140 mV at 1 kHz, 160mV at 20 kHz
Gain (at 1 kHz) 35 dB
Crosstalk (at 1 kHz) 80 dB
RIAA Response +/- 0.5 dB (100 Hz to 20 kHz); -1 dB (20 Hz)
THD+N (at 1 kHz, 5 mV input) 0.05%
S/N Ratio (ref. 5 mV at 1 kHz, IEC-A filter) 83 dB
PREAMPLIFIER
Input Impedance 30 kΩ
'Pre-Out' Output Impedance 560 Ω
'Rec-Out' Output Impedance 100 Ω
Rated Input 1.0 Vrms
Maximum Input 7.6 Vrms
Minimum Load 5 kΩ
Rated Output (100 k1 load) 1.0 Vrms
Maximum Output (100 k1 load) 7.6 Vrms
Headphone Output 500 mW into 32 Ω at 0.03% THD+N
Channel Separation (at 1 kHz) 75 dB
Crosstalk Between Inputs (at 1 kHz) 72 dB
XLR Pin Configuration Pin 1: Ground; Pin 2: Positive; Pin 3: Negative
Frequency Response and Bandwidth 20 Hz to 20 kHz (+0, -0.1 dB); 1 Hz to 170 kHz (+0, -3 dB)
THD+N (at rated input and output, 80 kHz BW) 0.003%
IMD (CCIF at 15 kHz and 16 kHz) 0.0005%
S/N Ratio (A-weighted, ref 2.0 Vrms) 105 dB
POWER AMPLIFIER
(per channel, continuous RMS, 20 Hz to 20 kHz, <1.0% THD)
Frequency Response 20 Hz to 20 kHz (+0, -0.15 dB)
Bandwidth 1 Hz to 200 kHz (+0, -3 dB)
THD+N 0.01% at 1 kHz, 0.03% at 20 kHz (100 W into 8 1)
Power Bandwidth < 10 Hz to 100 kHz (+0, -3 dB, 200 W into 8 1)
Slew Rate 25 V/µs
Headroom 1.4 dB (8 1), 2.8 dB (4 1)
Damping Factor 80 at 1 kHz (ref. 8 1)
S/N Ratio (A-weighted, ref 225 W) 105 dB
Crosstalk > 57 dB (100 Hz to 10 kHz)
Voltage Gain 29 dB
CONTROL
Infra Red
Carrier Frequency 38 kHz
Max. Emitter Current Pass-through of input
Trigger Input Polarity Non-polarized
Output Pass-through of input
POWER REQUIREMENTS
Impedance 8Ω 4Ω
# of Channels Driven 1 Both 1 Both
*Short Term 240 W 225 W (FTC) 330 W 310 W*
Power Consumption (8 Ω load) Maximum 800 W
Typical 300 W
Fuse Rating (Fuse is internal) Anthem serviceable only
Low Voltage Version: In countries where the line voltage is 120V, this product operates from a single phase AC power source that supplies between 108V and 132V at a frequency of 60 Hz.
High Voltage Version: In countries where the line voltage is 220V, 330V or 240V, this product operates from a single phase AC power source that supplies between 216V and 264V at a frequency of 50 or 60 Hz.
Dimensions
Width 5-7/8 inches (14.9 cm) including feet
Height Width 17-1/4 inches (43.8 cm)
Depth 18 inches (45.7 cm)
  • I love my Anthem 225.
    – Kevin Alfred Strom
    The creatures outside looked from pig to man, and from man to pig, and from pig to man again; but already it was impossible to say which was which.”……George Orwell-Animal Farm.
  • geppy1
    geppy1 Posts: 3,076
