Volume dial position to be audible?
rburgess714
rburgess714 Posts: 618
edited October 2020 in 2 Channel Audio
At what point on the volume dial does your system become audible? My integrated has no sound until I get to around 8 O’clock and at 9 it’s singing.
Living Room
Parasound HINT 6, Yamaha Aventage RX-A 1060, Oppo 103D, Cambridge Audio Azur 851N, KLH Model 5s, Polk CSi A6, Samsung 65" LED
Office
Yamaha A-S501, Auralic Aries Mini, LSiM 703s
Douglas Connection ICs and Cables
  • BlueFox
    BlueFox Posts: 15,250
    Don't know. My volume dial has no markings. Rather the display shows a number from 0-100. I can hear music in the teens, and I usually listen between 50-60.
  • BlueFox wrote: »
    Mine has no numeric markings just using a clock dial for a point of reference.
    Living Room
    Office
    msg Posts: 10,532
    edited October 2020
    Mine start coming in off minimum, but it's low. I can comfortably listen at o'clock, and it's usually the starting point for a good listening level in my setups. 10 o'clock starts to get loud.
    Does your source have a volume control as well?
    mhardy6647 Posts: 35,364
    edited October 2020
    A clean, properly functioning, and well-tracking stereo log taper pot ('volume control') should give nonzero audio output at any point "off the peg". Age is not kind to volume control pots -- and many, many, many pretty good components, over the years, used rather crummy quality pots to start with (lookin' at you, McIntosh C-28! :( ).
    Now, the other things to bear in mind are the 'value' (maximum resistance) of the volume control pot itself, the "taper" of the pot, the "gain structure" of the components in one's own particular hifi chain) and the sensitivity of one's loudspeakers. (oh, and also the senstivity of one's own ears and the background noise level in one's "hifi room").
    All of which is to say that it's gonna be somewhat system dependent. :#
    EDIT: Also probably worth mentioning that volume controls are - in virtually all cases - operating as attenuators. They reduce the maximum signal being supplied to the next stage in the amplifier (or component chain) from the maximum value.
    EDIT^2 FWIW I use a passive, constant impedance stepped (i.e., tapped) transformer attenuator for volume control, rather than the traditional "stereo pot".
  • invalid
    invalid Posts: 1,549
    Mine starts at about 8:00 and I can turn it to about 2-3 o'clock, my speakers are inefficient and my amps input sensitivity is 2.5 volts. The background noise in my dedicated room is very low.
  • Thanks for the feedback. Sounds like my integrated becoming audible at 8:00 isn’t necessarily out of the norm.
    Living Room
    Office
  • jdjohn
    jdjohn Posts: 3,415
    I would say another factor (perhaps more so with older pieces) could be cleanliness of relay contacts. As they develop corrosion over time, it takes more 'juice' to get the signal through. Of course if the amp is left 'on' all the time, it should make corrosion less likely to occur since the contacts aren't exposed to as much O2. But with the on/off cycle, microscopic sparks can occur that create carbon deposits on the contacts. And with older pieces that have sat unused for several years, having the relay contacts 'flapping in the wind' (so to speak), can create a thin layer of corrosion. This is why relays are inside little boxes - to minimize air contact.
    F1nut Posts: 52,142
    It's a Musical Fidelity M6Si.
  • Emlyn
    Emlyn Posts: 4,866
    I would not be concerned. I would be concerned if the volume control could not be adjusted in increments to set the volume at a variety of comfortable listening levels. A big variation in output from 8 o'clock to 9 o'clock may indicate that the gain is a little high or speakers are very efficient?
    With an Anthem Pre-2L SE tube preamp I have there are three gain settings inside. The original model had a remote with volume adjustments that were too big resulting in barely audible music at one setting to blasting with one button push. That problem was corrected later on.
  • F1nut wrote: »
    Yes it is. I assume it’s no big deal?
    Living Room
    Office
    F1nut Posts: 52,142
    Nope. My MF dial mark starts about 7, which is no sound. I guess about 8 it's making sound, but I never turn it down that low.
  • Emlyn
    Emlyn Posts: 4,866
    Parasound JC2 is similar. Control starts at 7 on the dial and best sound is between noon and 1 depending on the source. Not much sound going on at 8. Parasound says the best "bloom" is designed into the preamp between noon and 1 on the volume control.
