Older sanyo tv
terrytraci
We have a sanyo model Dp50741
And cannot figure out how to set our Polk signature S2 sound bar to it. We need a optical cable with a different end to plug into the tv. We ordered a mini to slink to toslink cable but still not working. Also the guide says to turn off the internal speakers but our tv doesnt have that option.
Thank you for the assistance!
I stand corrected, see posts below.Post edited by F1nut onPolitical Correctness'.........defined
President of Club Polk -
Looks like it has analog L and R outputs, so you can connect it to the Aux in on the soundbar.
Using one of these cables:
Or, if you wanted to let the soundbar do the converting from digital to analog, get one of these which will convert the TV's digital coaxial output to an optical output that the soundbar accepts. https://www.amazon.com/Digital-Coaxial-Optical-Converter-Bi-Directional/dp/B07VHPJ1DD
I would recommend this: https://www.amazon.com/Optical-Tendak-Bi-Directional-Converter-Splitter/dp/B06XCTGZFT/ref=mp_s_a_1_1_sspa?dchild=1&keywords=coax+to+optical+converter&qid=1603045565&sprefix=coax+to+op&sr=8-1-spons&psc=1&spLa=ZW5jcnlwdGVkUXVhbGlmaWVyPUEyRzZEOE9OM1ZRVVRPJmVuY3J5cHRlZElkPUEwNTg2MDg0MzhMUDlTMEpSMVoySCZlbmNyeXB0ZWRBZElkPUEwMTYzNzMxMlAxWklXSkVZMlNDQSZ3aWRnZXROYW1lPXNwX3Bob25lX3NlYXJjaF9hdGYmYWN0aW9uPWNsaWNrUmVkaXJlY3QmZG9Ob3RMb2dDbGljaz10cnVl
And then you will need these: https://www.amazon.com/AmazonBasics-Digital-Audio-Compatible-Coaxial/dp/B01D5H8TS4/ref=pd_aw_fbt_img_2/144-0956091-7347721?_encoding=UTF8&pd_rd_i=B01D5H8TS4&pd_rd_r=c0689d23-4cd8-4dd3-8519-73d080926335&pd_rd_w=OxZBJ&pd_rd_wg=4g7Zc&pf_rd_p=e5143995-bc4c-4e22-9b66-79eb4d8ad240&pf_rd_r=D6WRQGMZ1FYA77W1PY6D&psc=1&refRID=D6WRQGMZ1FYA77W1PY6D.
And https://www.amazon.com/AmazonBasics-Digital-Optical-Audio-Toslink/dp/B00NH11H38/ref=pd_aw_fbt_img_3/144-0956091-7347721?_encoding=UTF8&pd_rd_i=B00NH11H38&pd_rd_r=c0689d23-4cd8-4dd3-8519-73d080926335&pd_rd_w=OxZBJ&pd_rd_wg=4g7Zc&pf_rd_p=e5143995-bc4c-4e22-9b66-79eb4d8ad240&pf_rd_r=D6WRQGMZ1FYA77W1PY6D&psc=1&refRID=D6WRQGMZ1FYA77W1PY6DLiving Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es
Bedroom 2.1 Harmon Kardon HK3490; Bluesounds Node N130; Polk RT25i; ACI Titan Subwoofer
