Record Cleaning Machines
I'm thinking of stepping up to a record cleaning machine. I've been looking at used VPI 16.5 machines. Does anyone have experience with this machine?
  • I've had one for many years. Best investment I ever made to upgrade my vinyl experience. I've cleaned over a thousand records with mine. Buy a used one if you can. I could easily sell mine ror what I paid for it over 10 years ago.
    Main System 2.2:
    Proton AA-1150 ~ Yamaha C-4 ~ Furman Elite-15 DMi ~ Sennheiser HD600 ~ Monitor Audio Silver RS8
    (2x) Martin Logan Dynamo ~ Marantz CD5003 ~ Squeezebox Classic ~ Music Hall dac25.2 ~ Sansui D-X111R
    Dual 1229/Acutex M312 III STR ~ Music Hall mmf-5.1/Goldring 1012GX ~ Music Hall Cruise Control 2.0
    Home Theater 5.2:
    Yamaha RX-V800 ~ Furman Elite-15 DMi ~ Polk Audio RT55i ~ RT35i ~ CS400i ~ (2x) PSW450
    Winter Residence 2.1 (laptop system):
    Yamaha A-S301 ~ Squeezebox Classic ~ Topping D30 ~ EPI M90 ~ Dayton Audio SUB-1200
  • displayname
    displayname Posts: 1,237
    I haven't used the VPI 16.5, but it's one of the best reviewed RCMs of all time. I went with the Pro-ject VC-S2 Alu, but I was down to that or the 16.5.
    Discogs
  • Mike Reeter
    Mike Reeter Posts: 4,315
    I purchased a used 16.5 years ago, I've cleaned 100's of LP's and it's going strong. Only thing I've done it is install a longer Drain Tube to reach a collection jug. "If" you acquire one, clamp the Drain Tube when cleaning. This allows the most powerful suction on the LP surface. Only open the Tube to drain about every 8-10 LP's.
    Good Luck! If one is serious about Vinyl, you NEED a good RCM.
    F1nut Posts: 52,142
    Okki Nokki user, highly recommended.
  • displayname
    I looked at the Okki Nokki One pretty closely because from a feature/price standpoint they are really in a class on their own. But the unknown ship dates caused by their production/COVID delays turned me off.
    But if anyone is in a position to wait, the One does look like a smart design.
    Discogs
  • Thanks for the feedback. Much appreciated!!
