Is there an advantage to upgrading a router power supply?
I have an ifi iPower sms that might run my router, I got it for something else that it didn't work on. I figured I would ask here before I return it. It's nib because I got two just in case my experiment worked.
    msg Posts: 10,536
    Good question, and sounds like something I think maybe DK may have tested in the past? No personal experience here.
    I think @ALL212 tested some ethernet cables not too long ago, too.
    If you have audio components connected over ethernet to your wifi router, maybe worth checking out.
    I'd be curious to see whether it does anything for the signal, though maybe adjusting your wifi channels to be a bit offset from neighboring access points might be something else to look into as well. There are apps you can use to survey local wifi near you for this purpose.
  • jdjohn
    jdjohn Posts: 3,415
    Are we talking plunge routers, bench, or free-hand?
  • afterburnt
    afterburnt Posts: 7,892
    jdjohn wrote: »
    As a condition of parole I can't be within 100 yards of power tools so I am talking wifi.
  • afterburnt
    @msg, I got two of the same unit, one for my cheap TT (which is fine) and the other to try on my NAS (which it's not). I probably should return it an take a shot at the DC iPurifier that cost twice as much. You got some links for me to look at?
  • machone
    machone Posts: 1,573
    My experience is that any improvement in the power supply chain yields an improvement in sound quality and this is true with analog or digital.
    Is the juice worth the squeeze?
    That's up to the individual.
    1KVA Dreadnought
    Marantz SA 8005
    Sony PS4
  • ALL212
    ALL212 Posts: 1,668
    edited October 2020
    so many connections...
    WIFI is a chain, many potential weak links!
    Devices
    Power
    Power supplies
    cables
    Are you having wifi issues?
    It would be best to start with analysis of your wifi before starting.
    On the other hand plug it in - see what happens!
    Aaron
    Enabler Extraordinaire
