For Spotify use—Chromecast Audio + Cambridge 851D or Auralic Vega G1?
I’m currently using ChromeCast Audio device to stream Spotify to a Cambridge Audio 851D DAC...then to an integrated amp (Musical Fidelity M6Si). Will there be any noticeable sound improvement if I upgrade all the way to an Auralic Vega G1(or even G2) just to stream audio from Spotify?
Best Answers
  • rooftop59
    rooftop59 Posts: 8,120
    Answer ✓
    Seems pretty silly to me to spend that much $$$ to just stream Spotify. But I will say that I updrafts from a Cambridge 851d + squeezebox touch to an 851n and Spotify (the rare occasions that I listen to it) does sound about as good as I can possible imagine it sounding. But tidal or local flac files sound so much better...
    Game Room 5.1.4:
    Bedroom 2.1
  • rooftop59
    Answer ✓
    audioluvr wrote: »
    Could be other things downstream that are preventing your lack of differentiation on sources. Doesn't make a lot of sense to buy a $2,000+ DAC if you are using $50 lamp cord for speaker wire (for example).
    Yea I agree. If you can’t hear the difference now then there is no reason to upgrade. The 851N is a FAR better sounding streamer than that little chromecast...
    Game Room 5.1.4:
    Bedroom 2.1
Answers
  • I had the Cambridge 851N and used Tidal with it for a few weeks. Recently, I found a 851D for a good price and connected a Chromecast Audio device to it. I couldn’t detect any significant difference while listening to “master” songs on Tidal so I kept the cheaper set up. I understand that the DAC is the same in both units. Now I’m just wondering if the upgrading the DAC and streamer will yield any more improvement in streaming Spotify and Tidal.
    audioluvr Posts: 5,987
  • Thank you. I’ll hold off upgrading the streamer/DAC until I can get my hands on better speaker cables (currently using blue jeans cables).
  • rooftop59
    What are your speakers, interconnects, power cables? And what amp and preamp are you using?
    Game Room 5.1.4:
    Bedroom 2.1
  • IC: MIT shotgun S3 rca cable from Cambridge 851D DAC
    Integrated amp: Musical Fidelity M6si
    Speakers: polk Lsim707
    Stock power cables.
  • gyosa
    gyosa Posts: 770
    Biggest thing you could do to improve your sound quality is to ditch Spotify and go with either Tidal or Qobuz ...
    Spotify really sucks .....
    Bk
    PS Audio S300 , WiiM Ultra , Yamaha wxc-50 , Salk SuperCharged Songtowers , Kimber Kable 4TC, Sony 48” - BEDROOM
    B&K EX-442 ( it will go in my casket when I die ... ) , PS Audio 4.6 preamp ( old school , but it still jams on ... ) , Eversolo DMP-A6 , Boston Acoustic voyager 7’s - POOL
    Parasound A21, Eversolo DMP-A8 , Kimber Kable 4vs , Ascend Acoustics ELX Ribbon Towers , Sony XBR-A8F 65” OLED - DEN , MAIN system
    Onkyo TX-nr609 , Polk atrium 7 , Boston acoustic sound ware (4) , Boston acoustic sub , B&W center , Sony 65” TV - PATIO
