Need help finding a wall mount fan
afterburnt
I can't seem to find a small fan that will bolt to a wall something like the bus drivers had on their dashboard when I was a kid. At least they had em on the short bus.
Thanks I think can make this work. https://www.amazon.com/gp/aw/d/B07X5W3FZR/ref=sspa_mw_detail_1?ie=UTF8&psc=1
Battery operated though?
USB works, I need to place it above a window so I can rotate it down for exhaust. -
I will "Magiver" like a towel rack or something to mount it.
Image search of "wall mount fans" shows lot of styles. "Waterproof patio fans wall mount" has some nice ones too. Then click on the links to see which are easier to purchase.
