Power Cable for SurroundBar 6000
bniebel
I misplaced my power cable for my SurroundBar 6000. I contacted Customer Service and they said that a replacement would be sent to me, but it never arrived. Can you suggest a cable that I can purchase online that will work in the SurroundBar 6000? Thanks!
for instance - should this work?
https://www.amazon.com/HQRP-SurroundBar-IHT-6000-Soundbar-Sound-Bar/dp/B06XJ6TWGM
I own a SurroundBar 6000 and the voltage is right and the amperage required is compatible with the HQRP 24V AC Adapter from Amazon.
Thomyui12 reported
