speaker wire
Willow
I need an extra 2ft should I just add 2 ft of speaker cable to the existing or should I buy a whole new full length ?? I can cap of the added part with electrical caps.....this is for a rear speaker !! what should i do
Post edited by Willow on
Depends on the quality of your setup. Spilcing should be fine on the rears - I had to do it on my theater revamp. Runs were very long. I never spice on the front stage.
I thought its prob ok I dont want to but at the same time i dont want to pull up part of the carpet either
Willow, there's nothing whatever wrong with splicing as long as you take care to keep the two conductors separated.
spl
splice away with no heartburn amigo.
1/4twin***WAREMTAE***
