need surround advice
Bigdaddymech
I have a pair of the RT1000i 's and I am trying to choose some nice surround speakers I'm not one for wall mount or stand speakers I like towers. Is there any towers that you would recommend for rear surrounds? The ones I have in mind are the RT600i.Please help I'm new to this.
Post edited by Bigdaddymech on
sounds great.
If your buget allows, another pair of 1000i's would work nicely as well. -
Another pair of RT1000i can be arranged ,but I was told it would be a waste because only 15% of my signal goes to the rear speakers. Is that a true statement?
BigD-
Even the most aggressive 5.1 soundtrack, does in fact, send a much smaller percentage of information to the rears.
I think another set of 1000's would fall asleep.
Since their subs would not receive much action.
If you refuse to get fx500's or rt25..35's,
get a set of 800's.
At least your drivers would match those of your 1000's.
And if you decided to connect them to your B-side channel, (such as I did) you would find a sweet blend of more mids and highs mixing with the bass of your 1000's.
-luc -
Big D-
I was thinking about other considerations than just DD/DTS 5.1. I listen to a lot of music on my system and have a 5-channel stereo mode on the onk. 676 receiver that I like to listen to. This DSP mode supplies equal power to all 5 channels - so you can imagine how great it would sound with nice full range surrounds that matched the mains.
If your only concern is DD/DTS 5.1 then yes, they may be under utilized. -
I, myself have 2 pairs of rt800i's for 5 channel stereo, and especially dvd-audio,sacd. Sounds superb! I'd say go for the rt800i's !!
another vote for the 800i's, if you don't want to go with f/x500's or 35i's...
I'd say 35's or the 800's...unless you can find the 1000's open box and get a realy good discount..wich will probably comming up soon with the roll-out of the newer rt's.... I have 800's for surrounds with my 2000i's and they work great.!
Thanks for the advice the RT800i's will probably be my choice.Like I said before I'm new to this and to club polk so you will be hearing from me real soon.THANK GOD FOR CLUB POLK!!!
