RT series in-wall speaker questions
Hi all,
Recently moved, new house will not work so well with current RTiA7/CSi A6.
How do the 255c/265RT in-wall's compare?
Will these be sufficient? My plan is to repurpose the A7's and rear surrounds and put some RT timbre-matched in-ceiling speakers to go 7.4.1.
Thanks!
Thanks!
The 265-rt is great. You'll love them.
Don't bother with the 255c. Your much better off using the the same 265rt for your center as well. -
The 255c not so good?
Also - ceiling speakers. VT vs RT... is VT timbre matched? Seen many recommending them. -
RT ceiling speakers to match with RT wall speakers
TopperDude wrote: »The 265-rt is great. You'll love them.
The 255c-RT is timbre matched, and in some situations, a third 265-RT might be aesthetically less appealing (and AFAIK, it should not be installed "sideways" to overcome that limitation).
Alea jacta est! -
The most ideal and most seamless is to use 3 same speakers to handle front LCR vertically mounted (applicable when you use acousticaly transparent screen). If using tv, then you'll need to orient your center horizontally which is your first compromise. No need to compromise further with different smaller speaker to handle center.
How do the RT compare to the LS?
