660 wi polk sub don't stay on
Basie
Same as all the other Guys, my sub don't stay switched on. Can i connect it direct in some way so i can bypass that little auto power switch with seems to be the problem?
Answers
According to the owner's manual when the rear panel selector is in the "On" position the sub is always powered on. There doesn't appear to be a way to bypass this selector.
There is defiantly something wrong with part that is suppose to respond to the signal from the receiver. However there is a third option to connect your sub from the “front” speaker out on the receiver to the sub and then from the subs connections L&R to the front speakers, is that right?
Thanks -
That is correct, either a line level or speaker level input connection.
Amazing amp, all of a sudden I experienced the same issue, it just kept powering off after a few moments. I have an avionics background and felt compelled to fix the issue. Removed the back panel, and inspected the PCB, components, terminations. Found that some bugs desired to short a couple of components. Carefully cleaned all the terminals well and replaced the power control IC CQ1565RT. Tested several hours now. While waiting for the power control IC I upgraded the speaker wires. Sounding better than a million dollars!
