Can I use my Command Bar with another Alexa hub?
The Alexa app keeps losing my Wifi connection but otherwise works fine. Can I just get another hub to use with all my Smart Devices?
I am sold on Smart products so I want to continue using them and I like the Command Bar.
Answers
    F1nut Posts: 52,244
    The trouble is they aren't actually smart.
  • Hardyguy10
    Even though the set up would not work to reinstall Wifi, the internet started working again on my Command Bar last evening. I would still like to know if I buy another Alexa hub, will my Command bar work as just another Smart device?
