Can I set up command bar without using alexa
jondoe1
Answers
Alexa comes on but you don't have to use it or connect to Wifi if you wish.
Yes you can use it just as a sound bar.
probably best to set it up on Wi-Fi to get the latest software updates then do a factory reset afterwards
