Any thoughts or owners on/of Unison Research Simply Phono Tube Stage
gfong
gfong Posts: 1,079
Anyone own one or had one or heard one before? Any feedback would be appreciated.
Can’t find recent reviews, not sure what cartridges would work with it? Seems to be more for MM and mid to hi output MC.
Type : Stereo Phono Valve preamplifier
Classe: pure A class
RIAA : passiva +/- 0.2 dB ( 20 Hz / 20 KHz )
Output Impedance: 800 ohm.
Uscita: 1 x line
Gain : 52 dB
Total Harmonic Distortion (THD): 0.4 % at 1 volt output
Signal to Noise Ratio (S/N): – 72 dB
Inputs: 1 x fonorivelatore MM o MC
Input Impedance: 47 Kohm – 100 – 50 – 22 ohm / 100 pF (modifiable)
Feedback factor: 0 dB
Valves: 4 x ECC83 / 12AX7
Right now I’m using a Rega Planar P6 with a low output Rega Ania cart with Rega Aria Stage.
I just purchased the Simply Phono new in box as I could not pass up on the price. Don’t think it will work with my Ania cart but I can change out carts if it sounds good.
Of course would go with my Unison Research Simply Italy tube amp hence why I purchased it.
