S35E Center Speaker
Danny_Deroye
in Speakers
Hi to all.
My idea is to use 5 x S35E center speakers.
2 x S35E for the front left & right.
1 x S35E for the center.
2 x S35E for the rear left & right.
Then I want to use 1 x HTS15 or 2 x HTS10
I don't have much room for big front speakers and the center speaker look good.
I read in the commercial that the S35E could also be used as front speakers.
Who can help me, if necessary I can adjust the filter of the front for more bass.
Thanks in advance.
Thanks in advance.
Yes sir you can definitely do that as the S35 is an L/C/R meaning it can be used for vertical left and right and horizontal center all wall mounted around your tv.
I've done a few setups using s35 and fine a crossover point of about 120hz works really good. Highly recommend multiple subwoofers as well to make the bass more seamless. -
Thanks for the replay.
