AI-1 Dreadnought question.
VSAT88
Ran up on a 1000 VA TIS1000-2120 50 HZ Bridgeport Magnetics isolation transformer. Would this be a decent choice for darkknight style dreadnought build ?
There are audio quality (ultra low noise) 1:1 isolation transformers and then there's everything else. Get the 800VA Avel and be happy.Political Correctness'.........defined
President of Club Polk -
Thanks @F1nut . Found that one right away. 111.00 at Parts Express. No shipping fee.
I don't see the Y236906 available at PE.Political Correctness'.........defined
Not all are built the same or suitable for our use. Ray did a bang up job looking at several and these two came out on top after he put them all though his testing.
The 800va ( Y236906) is a fine piece and I was totally satisfied with mine. -
I just typed in "800VA Avel" and Parts Express was the first 800VA that came up. I did not have the model number. Guess I need to look again somewhere else.
Yep, they have a 6903, 04, 05, 07 but wait for it.. No 6906.
Y236906 is an off the shelf item at Avel.
Yep. I will email them then. Thanks fellows.
