Center channel speaker question
HowieDoin2
in Speakers
Hi folks. Looking for some input on what I could use for a Center channel speaker for a 5.1.2 setup that currently putting together. I have everything I need except for the Center.
2 x rc65i for front left and right
Polk sub
2 x rc60i ceiling speakers for Atmos
2 x rm7 for surrounds
I’m hoping to use an in wall for the Center if I can and came across the Polk Audio IW65 6.5. Anyone tell me if that would do the trick? Lot cheaper than the dedicated Polk Center channels I’ve seen.
Thanks!
Polk sub
Thanks!
I guess I’ll answer my own question. I ended up getting the cs10 which I’ll put on a floating shelf under the mounted tv, was on sale for $98. Everything I read about it makes it seem like it will be a good match, hope so anyways.
Hello Howie, I'm in a similar situation and I'm wondering what your opinion of the CS10 is now after a few months of use?
