LSiM-707s or 705s with my Denon AVR-4800 (125Wpc)?
noupdjm
noupdjm Posts: 4
I am setting up a home theater room in my basement. I have a Denon AVR-4800 as my centerpiece. Would you recommend LSiM-707s or LSiM-705s as my choice of speakers?
Best Answers
  • Emlyn
    Emlyn Posts: 4,838
    Answer ✓
    Either set of speakers would work. The 705s would be my choice though. A separate two channel amp in the 200 watt per channel range would improve the output too.
  • Emlyn
    Emlyn Posts: 4,838
    Answer ✓
    The 705s sound more cohesive for two channel music use compared to the 707s, which sound a little bit like a large monitor sitting on top of a subwoofer. It's subtle but overall I think the 705s are a little bit better integrated as a design even though they are a bit smaller. There's not much of a difference in power requirements between them. I have 707s in a home theater system, but only because the company sent me a pair of those by mistake when I ordered a pair of 705s.
Answers
