Mm2124
Systems
Hey guys I currently have a 12" Kicker Comp sub in a box designed for that sub.(HC12 combo) seen here.. http://www.crutchfield.com/S-daXzOkqLjV7/cgi-bin/ProdView.asp?s=0&c=10&g=510&I=2063HC12&o=p&a=0&cc=01&avf=N&search=
I am using a kenwood a kac 650 amp ...seen here to power all my interior speakers and the sub. (5 channel amp)
http://kenwoodusa.com/product/product.jsp?productTypeId=11&sortBy=price&productId=2426
My question is I'm thinking about exchanging the kicker comp sub and putting in a momo 2124 sub in the box I have. My question is will my amps sub channel be enough to power it and will that speaker sound alright in the box I have. The amp sub channel is rated at:
2 ohms- 300 Watts x 1
4 ohms- 200watts x 1
Prob not enough juice
Testing
Testing
Testing
Testing
Testing
You're right. The VC on the polk sub is 4 ohms, so you'd be giving it less than half it's rated power. I don't think it'd perform very well for you without more power.http://www.silverdragon.com/punkie/cybertusk/net.idiot.html - Read it, know it
Alpine 9815
Ascendant Audio Atlas 12
2 Gallons SecondSkin Spectrum V.2
