Need a DSL modem/router
muncybob
It seems we go through one pf these things every 18 months or so. Currently have a CenturyLink and it does a decent job accessing the internet and wireless streaming to the TV. Lately I'm having to reset it just about every day which from past history tells me it's on the way out.
Sure would like to find one that can give us a few years use for less than $100.
Yep, my name really is Bob.
If it has an external power supply you might try changing just that first.Expect that there will be bumps in the road. Choose to not let them rattle you.
Boston - CR7, CR6s, CR4s.
Thompson Adventures, Inc. -
Personally, I prefer a separate router and modem. A good router should last for many years and it is much more configurable than what you get from your ISP (CenturyLink?) DSL modems are sometimes locked to the provider, but I'm sure if you go out and do some Googling, you will figure out what is possible with your ISP.
A quick search found this:
https://www.centurylink.com/home/help/internet/modems-and-routers/compatible-modems.html
Looking at that list, it seems most of the compatible modems are all-in-one with routers. There is one (Zyzel Q100) that is a stand alone modem, but it seems to be out of stock or unavailable.
I have Comcast and I've been using a Linksys/Cisco DOCSIS3.0 modem since around 2015 with no issues. I bought a replacement around 2016 to keep in the closet, but I haven't needed it. My router has been up and running since around the same time with no issues.
For a wireless router, I've had good luck with the offerings from Asus. I usually stay away from their latest and greatest (fastest) models. Most of the time, they have a model that a few years old, which is proven and gone through a few minor revisions (like the RT-AC68u). Those are the ones to get. -
All routers that aren't provided by your ISP should be updated at least once a year with the latest firmware. It improves resistance to attacks, which have increased dramatically. If you're using an approved all-in-one modem/router, firmware will be managed for you by the ISP.Expect that there will be bumps in the road. Choose to not let them rattle you.
Well this isn’t much help, but I use Motorola surfboard cable routers with google mesh WiFi system and it’s awesome! Just like audio, I would definitely go separates if you can...Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es
Bedroom 2.1 Harmon Kardon HK3490; Bluesounds Node N130; Polk RT25i; ACI Titan Subwoofer
