Shunyata Everest power distributer is shipping
BlueFox
BlueFox Posts: 15,250
Supposedly the best around. Based on previous Shunyata gear, I suspect it is.
https://shunyata.com/products/power-distributors/reference-line/everest-8000/
    F1nut Posts: 51,943
    Those pieces around the sockets are strange.
  • BlueFox
    edited June 2020
    Yes, but they are practical. The big power cords when hanging down tend to pull out from the sockets. Those hoods keep the cords in the socket. I told them in the past to turn the sockets upside down so that gravity will push the cables in for a better connection, but they didn’t take my suggestion. :)
    Clipdat Posts: 13,100
    Did you preorder one?
  • Thorton
    Thorton Posts: 1,324
    BlueFox wrote: »
    Or so they only properly fit Shunyata power cords. They should sell it as a package deal.
    DAC: Bricasti M1SE
    Pre/Pro: Marantz AV8805
    Subs: 2 - Rythmik F25's
  • BlueFox
    edited June 2020
    All decent power cords have that issue.
    No, I didn’t order one. I would need three. One for each amp, one for three pieces of gear, and that is impractical. I already have the previous top of line gear, so I’m not losing any sleep over this release. Let’s see what’s next. Once I sell my Maryland house I will have more than enough money to waste. :)
  • motorstereo
    motorstereo Posts: 2,359
    edited June 2020
    The entire unit only weighs 34lbs...........imo that's a rather lightweight transformer for 20 amps and 8G's.
  • BlueFox
    Technology.
  • tophatjohnny
    tophatjohnny Posts: 4,189
    edited June 2020
    Model 8000...price 8000 man that was quick at the planning board. 😂🙊
  • BlueBirdMusic
    BlueBirdMusic Posts: 2,806
    I wonder if there are any little miniature frozen mountain climbers that come with it.
    Harry / Marietta GA
    mhardy6647 Posts: 35,198
    BlueFox wrote: »
    Technology.
    Less weight for more money?
    Sort of like Apple phones.
    It's not an isolation transformer.
    edited June 2020
    BlueFox wrote: »
    Taking a look at the product's description: "All outlets deliver both exceptional high current performance and standard-setting noise isolation that virtually eliminates component-to-component interference.
    There are no current delivery restrictions of any kind within the Everest. Instead, DTCD® (dynamic transient current delivery) is markedly improved across all outlets."
    It sounds like you actually wouldn't need three, and that everything could be plugged into this one unit. Might want to reach out to Shunyata to confirm that, but I'm not seeing any warnings against plugging high current monoblocks into this.
    edited June 2020
    Edit: Double post.
  • BlueFox
    Clipdat wrote: »
    I used to have just one dedicated outlet, and everything was plugged into my Triton. However, when I played it loud, the breaker would trip. I then had another 20 amp line installed for just the amps. Same problem. Playing loud would cause that breaker to trip. So I had a third 20 amp line installed, one for each amp. Now I could play it loud, and not trip any breaker. Of course, I did blow up both speakers one night playing it too loud. :)
    Yikes. Those Pass Labs amps are insane!
  • BlueFox
    Yes. After breaking both speakers I calmed down. Now it rarely gets into the 90s on the DB meter. Sounds fabulous now.
  • motorstereo
    As an experiment a few months back I plugged both my 1200 wpc amps and entire front end into my Furman ref20i on a single 20 amp circuit. Dynamics seemed to suffer slightly at extreme levels but other than that the rig sounded fine with no popped breakers. I wonder how the Everest would fare in a similar situation?
