Monitor 7 new to me
Hi,
After getting a lot of excellent help from you guys about recapping my Monitor 10 Series 2s, I ended up running across a set of Monitor 7s for $150 (hopefully a good price!). They appear to be from around 1986 and appear to have the maligned S2000 tweeters. And I think the magnets have started shifting on the drivers. On the plus side, they have real wood veneer. I wonder if someone could please tell me, from looking at the pics, are the drivers worth saving if I glue them? I haven't even played them yet for fear of them locking up or whatever. Thanks again!
Joel
  • Gardenstater
    Gardenstater Posts: 4,804
    Why do you think the magnets have started shifting? Have you done the test with your fingers evenly placed just around the dust cap and carefully pushed and listened/felt for voice coil rubbing? No way to tell by just looking. If they pass the test I'd definitely glue them up before using them very much. The SL2000s can always be replaced with the RDO-194s if you wish.
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
  • hobbyist49
    hobbyist49 Posts: 19
    I forgot to mention, the cones move in and out freely without scratching noise.
  • Gardenstater
    Well then you are in luck and I'd say they have probably not started to shift :)
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
  • hobbyist49
    I was (maybe incorrectly) assuming that because the magnets are off center. Thanks for the reassurance!
  • Gardenstater
    edited June 2020
    Although FAR from ideal, I believe the magnet can actually be about 1/8" off center before it will start to rub on the voice coil, due to the fairly large hole in magnet (approx. 1.3"?). Ideally everything should be concentric (base plate pole piece, voice coil, magnet, pole piece). I don't know how sloppy Polk was with centering the magnets.
    How much off center does your magnet appear to be relative to ?:
    1) Base plate pole piece
    2) Pole piece
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
  • hobbyist49
    I think it's a bit more than 1/8". These pics aren't very good, but might be illustrative.
  • Gardenstater
    Yeah those magnets are pretty off center relative to the pole piece. Is that mirrored on the base plate pole piece and minimums and maximums are in same polar locations? Anyway, the offset from center = (max - min)/2. It's hard for me to tell from your pics and that ruler doesn't even begin at 0 lol.
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
  • Gardenstater
    edited June 2020
    I don't know if this means:
    1) Your magnets have slipped
    2) Polk was just sloppy at times with centering of the magnets
    3) They did this deliberately to compensate for assymetrical magnetic flux density of a particular magnet.
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
  • hobbyist49
    Yea, sorry that pic is upside down :-). Yes, the off-center is mirrored on the top/front plate and back plate (not sure if I'm using the right terminology). I got some two-part loctite epoxy, so will glue them up today. Is it sufficient to glue at various points along the perimeter of where the top plate meets the magnet, or do I also need to hit the underside, where the magnet contacts the back plate? Again, thank you for all your advice.
  • Gardenstater
    I think if you are using epoxy you can just do various points, rather than the entire circumference. You do definitely have to do where the magnet contacts the base plate pole piece too, even though it is a bit harder to get to. If you don't the pole piece + magnet could still slip relative to the base plate pole piece and you've got a pinched voice coil.
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
  • motorhead43026
    motorhead43026 Posts: 4,031
    edited June 2020
    All the MW’s in my speakers look like that to varying degrees and they function just fine.
    – Kevin Alfred Strom
  • hobbyist49
    Thanks to you both!
  • hobbyist49
    Got them glued, used JB Weld Steel Stick...that stuff isn't as easy to work with as I thought it would be :-). Also ordered the RD0-194s. Polk still has them and still honors the Club Polk discount.
    pitdogg2 Posts: 27,335
    Have you guys ever seen speaker drivers built ?
    You do know while being built they are just ferrite cores non magnetic
    They are not magnetized until after the drivers are glued up and dried.
    So they wouldn't be compensating for any sort of magnetic flux
  • Gardenstater
    edited June 2020
    No I actually haven't. That would make it a lot easier to do the glue up. So now we're back to the question of why his magnets are so out of concentricity with his pole pieces if there has been no slippage, and how if there has been slippage, is he not experiencing voice coil scraping. Seems like it would require tremendous luck for that to have occurred.
    The only thing that makes sense(?) is that Polk glued them up like that or someone else manually moved the pole piece after the magnet slipped and managed to get it right and maybe put some loctite or super glue or something on it.
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
  • hobbyist49
    Since the Steel Stick has a cure time of 60 mins, I went ahead and fired them up just now for the first time, and they sound fantastic. I guess if they don't move any more, I should be OK :-). Thanks again for the help. Next on the list will be caps, at some point.
    Many magnet slips do not readily appear any different than they did before slipping.
    txcoastal1 Posts: 13,519
    So when a slipping magnet slips, how do you know it's slipping, or is that a slippery slipping question going down a slippery slope
  • teekay0007
    teekay0007 Posts: 2,288
    txcoastal1 wrote: »
    Wiener dog!! 🐶
    F1nut Posts: 52,009
    Would make a great avatar.
