Amp or Receiver to pair with Atrium 6s?
mikahc38
mikahc38 Posts: 9
edited June 2020 in Speakers
Hi.
I am looking to purchase a pair of outdoor speakers to mount underneath the eaves of my shop which is perpendicular to the shallow end of our pool pad where our pool chairs and table are located. Our pool is a 16 x 32 with a pool pad that is 12' shallow end x 10' right side x 6' left side x 6' deep end.
I have been researching purchasing either the Polk Audio Atrium 6 outdoor speakers or the Klipsch AW-650 outdoor speakers. Leaning towards the Polk Atrium 6s.
We want a good sounding outdoor speakers that we can use our phones to connect via Bluetooth.
Not sure what amp or receiver would be best paired with the Atrium 6's where we can use Bluetooth.
Any suggestions or recommendations?
Thanks and kind regards.
Mikah
Post edited by mikahc38 on
    F1nut Posts: 52,067
    Good sounding speakers will be negated by the piss poor audio of your phones.
  • mikahc38
    mikahc38 Posts: 9
    edited June 2020
    Ok. So, what do you recommend?
    Good sounding speakers will be negated by the piss poor audio of your phones.[/quote
  • rooftop59
    rooftop59 Posts: 8,120
    Eh, outside sitting by the pool sipping on a cold adult beverage, I really like the option of bluetooth or satellite radio or spotify connect, etc. Basically any good ole 2 channel integrated or receiver with something like this would do the trick: https://www.monoprice.com/product?p_id=38071&gclid=CjwKCAjwztL2BRATEiwAvnALcqQ5VbrGcXliA73oftLmLVEQKrvBeURaisA6RZvq7OYx_SnaQMQR9hoCajYQAvD_BwE
    Or even simpler, get something like this and call it a day: https://www.crutchfield.com/S-rBtCtjgiyLu/p_022RS202/Yamaha-R-S202.html
    If you want a little better SQ on the patio, add on old CD player or logitech squeezebox to the setup.
    Game Room 5.1.4:
    Bedroom 2.1
  • gyosa
    gyosa Posts: 770
    Airplay would be far superior to Bluetooth ....
    Bk
    PS Audio S300 , WiiM Ultra , Yamaha wxc-50 , Salk SuperCharged Songtowers , Kimber Kable 4TC, Sony 48” - BEDROOM
    B&K EX-442 ( it will go in my casket when I die ... ) , PS Audio 4.6 preamp ( old school , but it still jams on ... ) , Eversolo DMP-A6 , Boston Acoustic voyager 7’s - POOL
    Parasound A21, Eversolo DMP-A8 , Kimber Kable 4vs , Ascend Acoustics ELX Ribbon Towers , Sony XBR-A8F 65” OLED - DEN , MAIN system
    Onkyo TX-nr609 , Polk atrium 7 , Boston acoustic sound ware (4) , Boston acoustic sub , B&W center , Sony 65” TV - PATIO
  • rooftop59
    edited June 2020
    gyosa wrote: »
    Bk
    Oooh that reminds me...this is your cheapest decent audio quality option to add to any 2 channel integrated or receiver:
    https://www.ebay.com/itm/Open-box-Google-Chromecast-Audio-Media-Streamer-Black/383570407702?epid=217053957&hash=item594e93f116:g:o1sAAOSwae9e1His
    And you don't have to have an apple device to use it...
    Game Room 5.1.4:
    Bedroom 2.1
  • mikahc38
    mikahc38 Posts: 9
    rooftop59 wrote: »
    I had looked up the Yamaha you linked too earlier today and wondered about that one. I was glad to see you linked to that one in your reply.
    So, I have read where people simply upgrade their amp and keep existing speakers and they notice a big change in the quality of the sound coming from their speakers.
    What is the biggest factor from one amp verses the next that would make this change?
    Is it mainly the watts per channel that affects this?
  • rooftop59
    edited June 2020
    If you're actually wanting better SQ, the yammie is underpowered and might disappoint you. If you want better SQ, the sky's the limit. What is your budget? Are you comfortable buying used?
    Current makes more of a difference than watts, but there are lots of other elements. Honestly, if you are comfortable buying used, there are some older non-hdmi AVRs that are beasts that would sound much better than a cheap new reciever. They had much bigger transformers, better parts, and were designed more for audio than video. E.g. something like this: https://www.ebay.com/itm/Yamaha-RX-V1500-AV-Receiver/333577729348?hash=item4daac83544:g:cmUAAOSwov5emfoV
    I had one many years ago and it was a very good sounding avr. And you could power multiple speakers down the road if you wanted, even run dual zones!
    Or, even a little beefier: https://www.ebay.com/itm/Yamaha-RX-V2500-HT-Receiver-130W-7-1-Channel-with-Remote-Bundle-Made-In-Japan/184312871759?hash=item2ae9e73b4f:g:3EwAAOSwiX9ezZIr
    Game Room 5.1.4:
    Bedroom 2.1
  • mikahc38
    mikahc38 Posts: 9
    rooftop59 wrote: »
    Hmm.. now you got me thinking.
    I have an older JVC sound system I bought back in mid to late 80s or early 90s. It had 5 or 6 separate components. 1. AM/FM Receiver. 2 Equalizer 3. Cassette player. 4 turntable.. and seems like on other component.
    Is it possible to add something to this to make it WiFi or Bluetooth capable and hook up outdoor speakers like the Atriums 6? The speakers that came with it are indoor speakers and are loke 3 ft tall and fairly wide. It was an awesome system best I remember.
    So, might could just get some good speakers and hook to my old JVC system.
  • TopperDude
    TopperDude Posts: 166
    if you do end up getting something new to power those Atriums, consider the Marantz NR1200 2ch stereo receiver. Has bluetooth along with network streaming / HEOS. Should be a good match.
  • mlistens03
    mlistens03 Posts: 2,767
    This definitely used to be true, and it still is, but the sound quality of phones has come a long way in the past years. I mean, I can distinguish my 2nd gen iPad Mini from my Marantz CDP, but that doesn't mean my iPad doesn't sound great, and my dad's iPhone XS sounds even better.
    If you can get a CD player it will sound better, but you won't have billions and billions of songs at your fingertips. If you can get a CDP like my Marantz CD6004 (Thanks again Drew!), which you can plug your phone into so you can use it's DAC, that will make huge strides towards better sound even when streaming iTunes or Spotify.
    gyosa wrote: »
    Bk
    Even with Bluetooth 4.0? I was under the impression that 4.0 would be equal or superior to Airplay. Well I'll take your word for it (And hunt down a way to airplay to try it out for myself :) )
    Oh, and I'd agree with the thought of getting an old top of the line AVR on the cheap. I found a Pioneer SC-25 for $50 at a garage sale, and it sounded great. :)
    Good luck! -Micah
  • mikahc38
    mikahc38 Posts: 9
    edited June 2020
    Well. I bought a set of Polk Audio 200 Patio speakers paired with a Sony 2 Channel 200 watt Stereo Receiver with Bluetooth inly because wanted something sooner rather than later and can be picked up today.
    I wasn't sure what speaker wire to get so ordered outdoor 16ga bare speaker wire.
    Hope to get hooked up this evening.
    Any helpful hints on what to do and be on lookout for hooking them up and anything on what not to do?
    Speakers will be minutes under eaves if my shop about 10 to 15 ft apart. 16ga speaker wire ok?
  • mikahc38
    mikahc38 Posts: 9
    mlistens03 wrote: »
    gyosa wrote: »
    Bk
    Good luck! -Micah
    Thank you!
  • rooftop59
    Atrium 6s are better speakers. Patience is a virtue!
    Game Room 5.1.4:
    Bedroom 2.1
  • mikahc38
    mikahc38 Posts: 9
    rooftop59 wrote: »
    I know. So true.
  • mikahc38
    mikahc38 Posts: 9
    Well. Got the Polk 200 Patio speakers mounted on shop and Sony 2 channel installed inside shop. Our pool pad is a much cooler place to hang.
    Sound on these suckers are good enough for us. Wife super happy. Can easily hear sound at deep end of pool that is 54 ft away.
    Can turn up loud enough to drown out noise from the neighbors nonsense and turn down low enough to have a conversation and still hear music really good.
    Thanks to all of you who gave advice and recommendations. Really appreciated
    Mikah
  • TopperDude
    Glad to hear final result turned out well :)
  • KAT
    KAT Posts: 1
    Are any Polk Outdoor Speakers Bluetooth
  • mikahc38
    mikahc38 Posts: 9
    KAT wrote: »
    No. You have to get an amp or stereo receiver that has Bluetooth capability to power the speakers.
