Who here does crossover work? For hire.
CH46E
CH46E Posts: 3,595
edited May 2020 in The Clubhouse
I need some help. Well, the Infinity RSII crossovers are above my ability. They are not going to be just swapping one for one.
I would like to have them rewired onto a 1/8 inch thick wood board that I can sink into a wood frame and place on the rear section of the speaker. Like a nice display.
I have almost all the parts now. Going to be ordering the resistors next.
The schematic is just too complicated for me to follow.
Thanks for any suggestions guys!
  • CH46E
    CH46E Posts: 3,595
    I did replace the bass section and the tweeter caps, but I'm not going to be able to finish. Between the mid section the resistors, coils and size constraints, it's just too much for me.
    F1nut Posts: 52,017
    Talk to westmassguy.
  • tophatjohnny
    tophatjohnny Posts: 4,189
    Amen!
  • DaveHo
    DaveHo Posts: 3,583
    None better!
  • CH46E
    CH46E Posts: 3,595
    Roger Wilco!
  • CH46E
    CH46E Posts: 3,595
    @westmassguy does this look like something you might be intrested in?
    It does not necessarily need to 1/8 thick wood board. Could be on anything really. Just want to be able to recess it a few inches into a frame. Open top.
  • CH46E
    CH46E Posts: 3,595
    No luck from Westmassguy, he said he does not do point to point and custom substrate. He recomended I reach out to Trey/VR3. Waiting to hear back from Trey.
    I tried Danny from GR Research as thier web site offers custom crossover work, but he declined saying he needed the entire speaker there to fix other problems with this model. Not sure he understood what I was looking for.
    If VR3 is not interested, do you guys have any other recommendations?
  • Gardenstater
    Gardenstater Posts: 4,804
    Perhaps get some perforated experimenters PCB board and practice laying things out on it to get a better feel for how you might lay the components out on a board. Once you have the layout that works with minimal wire lengths it might not be as hard as you think to point to point wire it on a wooden board.
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
  • maximillian
    maximillian Posts: 2,149
    Careful with vibration from the transducers. Can cause unwanted electrical noise, but worse is rub/buzz of the components. How will you prevent that on a wooden external board without making it look ugly?
  • CH46E
    CH46E Posts: 3,595
    So, where I get confused is the ground. Can I use a common ground?
  • CH46E
    CH46E Posts: 3,595
    edited June 2020
    That is what I had in mind. So it does not matter where on the "ground wire" I link in the ground side of the components?
  • CH46E
    CH46E Posts: 3,595
    edited June 2020
    anonymouse wrote: »
    If you use 12AWG wire, it will not make a difference. I'd suggest you hook up one side of the ground to the and the other side to the 3 drivers as shown in the schematic
    I don't follow. I think there were some types there.
    I have a source for some Nickel plated Fluoropolymer 16 awg to go from the crossover to the mids and the tweeters. Or... is nickle plated copper a bad idea for audio signal? I know it is good for corrosion resistance, but what about audio?
    Then some 12 AWG Silver Plated Copper Wire Black 19 strand SPC to fill from the crossover to the woofers.
    I'll have plenty left over to use in the crossovers.
    I run Audioquest CV8 from the amp to the crossover.
    I really appreciate your advice! Thanks!
    Post edited by CH46E on
  • CH46E
    CH46E Posts: 3,595
    Yes, much clearer. Thanks!
  • CH46E
    CH46E Posts: 3,595
    edited June 2020
    Question. If I wanted to cut down on the cost, where should I do it? The caps that are in parallel or the caps in series? I was thinking if I save some money on the parallel 12.5 and 6.8 in the mid section, I could spend more on the 150uf that is in series on the mid section. I would go from using Jantzen Superior Z-Caps to Jantzen Standard Z-caps for the 12.5 and 6.8 . There is also a 12.5 in series that I already have the Superior caps for.
    Cheers
