Can my new Denon DRA-800H receiver power a pair of LSI 15 speakers?
Hi All, Happy Friday! Long time Polk owner... first time poster. So, I just bought a new Denon DRA-800H 2 channel receiver rated at 100 watts at 8 ohms and wanted to get some nice Polk speakers to match with it. Always liked the looks of the LSI 15's and they always have great reviews. Some are available for sale close to me at an amazing price and I loved to get them, but not sure if my receiver would be way underpowered for them. I know the LSI's are 4ohm speakers and my receiver can handle 4ohm but again would the LSI's be too much for the Denon. Here's a link to the Denon receiver https://usa.denon.com/shop/DenonNA-networkaudioplayers/dra800h_d
  • Muchieman
    Muchieman Posts: 204
    edited June 2020
    @OP, your unit will drive those LSi-15's, no reason that unit wouldn't. Now all though that line has been Discontinued for about 10 years by PolkAudio if I remember right. You may want to give Polk Audio customer service department a call or shoot a email into them. Just to check and see if replacement driver's or XO are still available just in case you buy a used pair and you get them home and find something isn't working Properly.
    You may luck out and find a pair still in good working condition. Buying a pair of used 10 + years or older and going by looks alone I wouldn't recommend unless you can give them a good run though with a CD of your choice. If you can get them on the cheap, say 600 or less for the pair and Polk Audio can get you replacement driver's or XO if you happen to find something isn't right, than they may be worth the Hassle. Those where going for around 950 a pair new back in 2011. So at today's dollars worth 500 to 600 tops in good condition, fair to less than fair condition no more than 300 to 400 for the pair.
    Tank
    nooshinjohn Posts: 26,066
    edited June 2020
    That Denon will not be able to drive the LSi-15. I have owned them in the past, powered by a more robust receiver than the Denon, and it was not capable of running them. The problem is not getting sound out of them, but rather there being enough current capable of controlling them. The power supply in the receiver is just not up to that task.
    You will need a fairly good 4 ohm capable amp to run them safely. Anything else runs the risk of damaging the receiver (most likely), the speakers, or BOTH. I know this from first-hand experience. Specs on the Denon show it to not even be rated for a 4 ohm load, so you cannot use it, despite what the previous poster stated, so please ignore that advice.
  • vmaxer
    vmaxer Posts: 5,121
    I wouldn’t do it without a high current amp. I have had 2 pair and burned up the crossover by under powering them (clipping).
    Nice receiver though from what I’ve read.
    I still have one pair that have been sitting in the boxes for a few years.
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    PS Audio GCPH phono pre
    Sunfire CG 200 X 5
    Sunfire CG Sig 405 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Yamaha DVD-S1800BL/SACD
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
    pitdogg2 Posts: 27,576
    Muchieman wrote: »
    Tank
    Last I knew there was no parts left at Polk.
  • mlistens03
    mlistens03 Posts: 2,767
    Muchieman wrote: »
    Tank
    They had no parts for my 25s when I called a few years ago.
    mlistens03 wrote: »
    Muchieman wrote: »
    Tank
    Well I'm going off of what another member posted several years ago when he was looking for some drivers for the Lsi15's he was told then no parts available.
