Denon DRA 565 Receiver
Mountain1954
I have a Denon DRA 565 receiver that still sounds absolutely excellent. What type or class amp was in this unit?
Almost certainly push-pull outputs (probably push-pull parallel) operating in class AB.
https://www.hifiengine.com/manual_library/denon/dra-565rd.shtml has the English language operating manual and the service manual, which has the schematic. A quick perusal looks like four output transistors per channel (PPP).
HTH, as they say.
Thanks. I was just curious.
I double posted by accident. How I delete the other post?
I flagged your other post so it should be deleted. Or, as @rooftop59 suggested in the other thread, you can message the moderator & she can do it.
Thank you! I did just that.
