B&K ST 202 Amplifier Advice
ultrasoudproductions
edited May 2020 in 2 Channel Audio
Hello Fello Polkaholics.
I have come across a B&K ST 202 amplifier. Is anyone familiar with it? Do the pictures look accurate or has there been any modifications? I am trying to get information on it and it appears to be pretty positive so far. Some claim that it is very neutral, powerful (At 200wpc in 8ohms and 300 at 4ohms) and comprable to the Adcom 555. Is this true? If so, them seems to be a bargain for the asking price of $195. I have been wanting to get a Adcom 555 since it appears to be a very nice amp. I have come across a couple of Adcoms at that price but they have been grabbed B4 I am able to. The Adcom are usually around $350 to $500. I am looking to power a set of Polk SDA 1 or a set of Polk RTA12b. Is there any positive or negative information/advice I should know?
Thanks in advance,
Post edited by ultrasoudproductions on
  • gyosa
    gyosa Posts: 770
    Get it ...
    I have an EX-442 and love it ...
    Bk
    PS Audio S300 , WiiM Ultra , Yamaha wxc-50 , Salk SuperCharged Songtowers , Kimber Kable 4TC, Sony 48” - BEDROOM
    B&K EX-442 ( it will go in my casket when I die ... ) , PS Audio 4.6 preamp ( old school , but it still jams on ... ) , Eversolo DMP-A6 , Boston Acoustic voyager 7’s - POOL
    Parasound A21, Eversolo DMP-A8 , Kimber Kable 4vs , Ascend Acoustics ELX Ribbon Towers , Sony XBR-A8F 65” OLED - DEN , MAIN system
    Onkyo TX-nr609 , Polk atrium 7 , Boston acoustic sound ware (4) , Boston acoustic sub , B&W center , Sony 65” TV - PATIO
  • sucks2beme
    sucks2beme Posts: 5,694
    The 202 is getting a bit aged. That would be the biggie.
    F1nut Posts: 52,142
    Those big blue caps aren't leaking, so it should be ok. Of course, if they have never been replaced you should plan on doing so at some point. That goes for any of those amps you're looking at.
  • gyosa wrote: »
    Get it ...
    Bk
    Thank you Gyosa for the feedback.
  • sucks2beme wrote: »
    Thank you sucks2beme for the feedback.
  • F1nut wrote: »
    Thank you F1nut for the information. I have looked at other amps through the vents, but I don't recall ever looking at the inside of an uncovered amp B4. It appears to me to be extremely clean for the age, simplistic and uncluttered. But then again I don't know what I am looking at.
  • PhotonDon
    PhotonDon Posts: 13
    Howdy, I haven't been on this site in a while so I just saw your post. I have had extensive experience with this particular amp, all good. I bought mine from Audio Advisor in 1989 when their catalog was pretty much stapled together copy paper. I think it cost just over $500. I ran it it with Vandersteens, Snells, and Magneplanars. Now, I don't pretend to have golden ears, but the amp always sounded good to me.The Mosfet magic is real, very smooth and not hyper-analytical, just how I like it. It would get a bit warm with the Maggie's 4 Ohm load but not unbearable. I ran that sucker for well over twenty years without a hiccup until one day it just quit. It was replaced but not discarded. I finally got it repaired for not much money and sold it (at about 23 years old!) for over $300. You have the power wrong though. It put out 145wpc into 8Ohms, and I think 200 into 4. Good times, good amp.
    Spending way too much on audio for over thirty years.
