mid/woofer replacement for Lsim706c
Hi Friend.
I'm looking for a replacement 6.5 mid/woofer for the Lsim706c model, Where I can get it?
Regards
  • henryzalez
    henryzalez Posts: 5
    I have looked for it and it is difficult to get, it is not normal, in the back of the magnet it has a kind of plastic in the shape of a tip
    Viking64 Posts: 7,637
    It looks like someone is melting a giant Hershey's Kiss® on a gas stove.
    F1nut Posts: 52,027
    Judging by the look of the driver the cabinet was destroyed.
  • stangman67
    stangman67 Posts: 2,330
    lol yea, those are well build drivers, that basket took a hard hit to break it like that. Would hate to see the rest of the speaker. Polk can hook you up with a replacement if you can get ahold of them
  • henryzalez
    henryzalez Posts: 5
    the cabinet is intact without any scratch, everything in its original box and packaging, I bought it "as is" at auction, I think that in the store it received a strong blow that generated air that came out of the woofer damaging it. I was looking for the replacement on ebay and I wrote in the search bar "LSiM706c" and guess what ... there are many that are selling with one or two broken woofers the same way, maybe all was in the same truck that overturned. You can see it
  • henryzalez
    henryzalez Posts: 5
    stangman67 wrote: »
    yes i already wrote to Polk to find a replacement but still no answer
