s15 or s20 when paired with HTS10
iHambone
iHambone Posts: 15
Good day,
I'm replacing a 25 year old RM satellite w/ passive sub combo up front in a small home theater. I'm looking to purchase either the s15 or s20 bookshelf speakers to pair with an HTS10 subwoofer for both movies and music.
Sonically , if I plan on cutting the new bookshelf speakers off at 80hz is there any benefit to getting the s20 over the s15?
Thanks for any thoughts
  • rooftop59
    rooftop59 Posts: 8,120
    How big is the room? What will you be powering them with?
    If you have other options I would consider other brands of subs. Never was polks strong suit...
    Game Room 5.1.4:
    Bedroom 2.1
    msg Posts: 10,546
    Good notes above.
    For a smaller room, the S15s may be fine, but the S20s will breathe a little easier and have a bit more overhead. In other words, they may sound a bit fuller without having to crank them.
    With music in the picture, I'd probably lean toward S20s. They do quite nicely for music in a combo use system.
    Do you have stands for these speakers?
