Polk audio model 4's modded?
I picked up a pair of Polk audio model 4's recently and the crossover sticks out about a quarter of an inch from the speaker. they have little pieces of particle board someone put underneath where the screws go in the back not for screw holes but for support only. I took out the screws from the back of one of the speakers to fix it and found the reason they stick out is because they won't go all the way in without touching the back of the speaker. Any ideas? Thanks.
Best Answers
    F1nut Posts: 51,789
    Answer ✓
    That's a bucking magnet, which you don't need since CRT's are long gone. It's glued on, so very carefully pry it off.
    pitdogg2 Posts: 27,064
    Answer ✓
    kachilda wrote: »
    Yes something about crt's. I think they were televisions which as you stated aren't really used anymore.
    Yes that is how they shielded the driver so not to interfere with older CRT based TV's picture tube
Answers
