Bridged Amp Power?
  • PolkWannabie
    PolkWannabie Posts: 2,763
    edited May 2004
    I'd get away from thinking biamping ... with a Parasound or other equally good amp it won't be needed and without an x/o or high pass filter in front of the amp you'll be wasting most of the power you're trying to send to the higher frequencies.
  • AsSiMiLaTeD
    AsSiMiLaTeD Posts: 11,728
    edited May 2004
    Something I wouldn't have thought about...thanks for the input.
    This leaves me with scenario 1 then, which is the one I'm leaning towards anyway just because it gives me a bit more power.
    So I probably shouldn't bi-amp the center either then? Do you think the bridged 400 watts will be too much for the 250 watts center? I know that overpowering is better than underpowering, but I wonder about 400 just being too much???
  • PolkWannabie
    edited May 2004
    You won't damage the center with more wpc unless you play them at insane levels but remember you'll only really use the extra watts when you turn it up i.e. all the extra watts really do is provide extra headroom.
    A 200 wpc amp will provide another 3dB of headroom over a 100 wpc amp and a 400 3dB over a 200.
    My experience with speakers in general is that your ears will be the limiting factor in that they'll force you NOT to listen at high volumes unless the speakers are of exceptional quality regardless of what amp you are powering them with.
    In my own situation I can listen to the SRT's at significantly higher volume than the RTi12's simply because the quality that comes out of them is a whole different level i.e. they really don't sound that loud and are not fatiguing at all at much higher volumes than what I could play on the 12's. I suspect this is why there are warnings on the speakers regarding playing them too loud as unlike the 12's it is conceivable that one could play them loud enough to do damage without running out of the house because of what they sounded like at that volume.
    As far as amp connections go although I have three amp connections to each main i.e. Stereo array, SDA Array & Subs there really is no biamping going on as they all need to be independantly powered any way. I do have my center biamped but only because I had a leftover amp channel but it's not likely that it's producing anything much better because of it.
    F1nut Posts: 52,000
    edited May 2004
    Just to clear up part of this earlier discussion I talked with a few knowledgable audio folks (and one guy who didn't know ****) and the ratings for peak amps are listed as a total. Example, 120 amps peak is the total, but it applies to both channels, however it is not doubled. The rating for max. power consumption is listed as the total. Example, 1500 watts max. is the total and is not per channel nor is it doubled. It is, as Mark stated, highly unlikely that one would ever reach these totals under normal playback, but the figures will give you a good idea if the amp is a high current design and how much potential juice the thing may use.
    An interesting discussion, eh?
  • dorokusai
    dorokusai Posts: 25,576
    edited May 2004
    That's all well and good, but I verified that power consumption and amperage value with Parasound, and it's valid. It is per channel by design, and per John Curl. It's a theoretical limit.
    I did not mean to imply that it was what was occuring at my home, I simply stated a value potential.
    He also said, as mentioned previously, that it is close to impossible to reach those kind of values under anything but the most extreme conditions. That would be a transient level as well, not a sustained level, as the amp would give out prior to the condition.
  • AsSiMiLaTeD
    edited May 2004
    I think the ways amps are listed depends somewhat on the manufacturer. For Example, HK lists their amps as total for the unit, so my PA 2000 has 45 amperes total.
    Parasound lists their amps per channel. I just got off the phone with John in their technical center and had two questions:
    1 - THe HCA 1000A shows 45 peak per channel. Is that in fact peak per channel or peak total for the unit...he advised it was peak perchannel, not total for the unit.
    2 - If I run in bridged mode, will I get 90 peak amps? He advised that sort of, but not really, it is combined, with one channel handling the top of the waveform and the other handling the bottom...but I think I'm still really only getting 45 amps total, just + and -.
  • AsSiMiLaTeD
    edited May 2004
    So I wonder if maybe that was John Curl I just sopke with??? That would be cool...
  • AsSiMiLaTeD
    edited May 2004
    I'm sure you guys already have this, but I thought I'd share...good reading...
    http://www.parasound.com/pdfs/JCinterview.pdf
  • lonwa
    lonwa Posts: 83
    edited May 2004
    not likely, I would rather have him designing new AMPS, than answering tech calls.
    Sometimes good command decisions get compromised by bad emotional responses."
  • AsSiMiLaTeD
    edited May 2004
    Originally posted by lonwa
    not likely
    Oh I know, but that would still be cool :D
    F1nut Posts: 52,000
    edited May 2004
    It is both, per channel and total for the unit. See my comments above. There isn't any way that HCA 1000A produces a total of 90 amps peak.
  • dorokusai
    edited May 2004
    Yea PM, don't listen to those who manufacture and repair the amplifiers, listen to the Polk forum :rolleyes:
    F1nut Posts: 52,000
    edited May 2004
    My info came from 2 different manufacturers, Musical Fidelity and Audio Research.
    "120 amps peak is the total, but it applies to both channels, however it is not doubled."
    You could take that and say it's per channel I suppose. :rolleyes:
  • dorokusai
    edited May 2004
    Whatever, you win Jesse, this is utterly pointless. My information is from THE manufacturer in question here. If this was a MF issue, I know you would be all on top of the mountain at that time huh?
    I don't want you to lose sleep over vintage gear that comes close to the performance of new, limited production MF gear.
    F1nut Posts: 52,000
    edited May 2004
    I'm not looking to win or lose, just find out the answer. As I see it, it is a "any amp" question and I wanted to know.
    Comes close? Hell, it probably spanks my little amp, but don't you worry bro, I'm not losing any sleep.:D
  • AsSiMiLaTeD
    edited May 2004
    Just in case anyone cares, I decided I think:
    I'm gonna go with 2 HCA1500As, one for each front. And 2 HCA1000As, one for the surrounds and one for the center...
    I decided on the 1500s not really for the extra power, but for the MOSFET driver stage. After reading and understanding the added advantage of the MOSFET design, I decided that I wanted to get that for the fronts.
    Now to figure out where to get everything and how to pay for it...guess I still have a couple of months to work that out...
    F1nut Posts: 52,000
    edited May 2004
    We care.......and wait with baited breath for the review.
  • dorokusai
    edited May 2004
    Excellent choices.
  • AsSiMiLaTeD
    edited May 2004
    you guys know of a decent pre/pro I can get for around $500, or should I just save and spend more?
    I need at least DD and DTS 5.1...
  • AsSiMiLaTeD
    edited June 2004
    Well crap...
    Now that I've made up my mind on the Parasounds, I can't find any. I swear like two weeks ago there were fifty of these things on Audiogon and Ebay, now I can't find any...
  • tonyv1
    tonyv1 Posts: 365
    edited June 2004
    Audio Advisor's have some B Stock Parasound 1000 and 1500. These carry the full 10 ten year warranty on parts and 5 years on labor.
  • AsSiMiLaTeD
    edited June 2004
    Thanks for the link. I have three amps to buy at first and was hoping to buy used a bit cheaper, but I'll keep that idea around in case nothing pops up...
