restoring finish on speaker cabinets
Was thinking about attempting to restore the finish on my Klipsch Forte speakers. There are some water stains, etc on them, mainly the tops. I believe this is an oak finish. I was thinking of using Howards Restor a finish using a "dark walnut" to help cover the stains. Hoping to get some advice on doing this. Not sure if I should do any sanding first , i understand the veneer is really thin. There arent any scratches, gouges, or any problems with the wood. Anyone used Howards , or any other products on their cabinets? Thanks for your help
Polk Audio SDA 1C, Klipsch Legend KLF 20, Klipsch Chorus II
    F1nut Posts: 52,294
    Do not ever use that Howards crap on anything.
    There's only one way to remove black moisture stains, Oxalic acid. You need to strip off the finish first though and it's best to apply the acid to every side on both cabinets.
  • stevep
    stevep Posts: 365
    Deck strength or diluted?
    F1nut Posts: 52,294
    edited April 2020
    Mix your own into a paste and pile plenty on the the black marks.
    WARNING: Do not breath the dried crystals as you clean the acid off the cabinets.
    audioluvr Posts: 6,055
    I've used Bar Keep's Friend on stains with success. Like Jesse says make a paste. I try to just put it on the stain itself first. May take several applications with that stain as it's really dark. I've sanded mine down to get it acceptable. Then I use Minwax water based polyurethane with great success. That stuff has very little VOC' s, dries fast and is extremely durable. 3-4 thin coats work best.
