LSIM705 - No high frequency on one speaker
looks like i may be calling Polk.
Purchased through Adorama 12/18/2017
Before i do i want to know if there are any suggestion about troubleshooting my issue.
Noticed recently that high frequency on one of the speakers is barely audible.
I have played music from different sources and the issue is still the same.
Swapped speaker position. Moved left speaker to right and vice versa. issue seems to follow the same speaker.
Not sure if there is anything else i can try before calling or just go ahead and call.
AMP/Pre Pro: Outlaw 7000x, Marantz AV7703
Speakers: Fronts:LSiM 705s/ Center: LSiM 706c / Surrounds: LSim 703s
SUB: Rythmik LV12R x2
Source:OPPO UDP-203
  • ken brydson
    ken brydson Posts: 9,028
    Are the jumpers tight?
    Viking64 Posts: 7,636
    Yes.
  • gumbay13
    gumbay13 Posts: 360
    I just checked again. Yes they are.
    Source:OPPO UDP-203
    F1nut Posts: 52,024
    You likely cooked a resistor. Remove the crossover and look for a burnt one.
    F1nut Posts: 52,024
    The LSiM faston connectors have a safety tab, which makes them impossible to fall off.
  • gumbay13
    gumbay13 Posts: 360
    Thanks for the input gentlemen
    Source:OPPO UDP-203
    F1nut Posts: 52,024
    SoundForce wrote: »
    Um no actually thats exactly what mine did.. There are things are are " possible" when not easily probable..
    No, it didn't. Quit making up stories.
