3.1TL Sonicap vs Clarity CSA?
todmarsden
Yes. SoniCaps (Gen 1) sounded more natural and "warm", (if that's a good description) to me in my non-professional opinion. I left those in and used the Clarity CSA's elsewhere and moved them with a sale. Totally anecdotal; but, that's what I have...
I have Sonicaps in my 3.1TL's, but my 2.3TL's have Calrity Cap ESA's in them. I prefer the ESA sound to the Sonicap (a little too warm and lacking detail, IMO); Of course this is subjective. ESA's (haven't heard the CSA's) are not bright to my ears, and mine are pretty sensitive. I could imagine the ESA's in my 3.1TL's, but haven't actually heard them (butimagine they would be great). Also, I use the Duelund Cast resistors in the 2.3TL's and find them to be excellent. Again, I have never heard them in the 3.1TL's, so my opinion may be worth only a grain of salt.
"Have A Little Faith! And Everything You'll Face, Will Jump From Out Right On Into Place! Yeah! Take A Little Time! And Everything You'll Find, Will Move From Gloom Right On Into Shine!"- Arthur Lee -
Jantzen caps could be a contender as well. The superior z cap is nicely detailed but not fatigueing to my old ears. I have them in the HF side of my 1C, good luck on your build I think any of the ones you list and are mentioned would be very good choices.
RandyYamaha RXA1030, Yamaha CD-S2100, Yamaha AS-2200, Bluesound node 2i
Polk SDA2btl highly modded
Polk SDA 1C modded
Polk CS350 LS x2
Kimber 8TC
Sony 55" Bravia
Wish list SVS sub -
Here is a picture of the crossovers in my recent 1C buildYamaha RXA1030, Yamaha CD-S2100, Yamaha AS-2200, Bluesound node 2i
Polk SDA 1C modded
Polk CS350 LS x2
Kimber 8TC
Sony 55" Bravia
Wish list SVS sub -
When I rebuilt my 3.1's, I put in Clarity Caps in all positions (I didn't build the x-overs ) and the results were just too Bright and edgy for my taste, extremely detailed though, if that's what your looking for.
I later had the boards rebuilt with all Sonicaps and Mills Resistors...much better. The single tweeter in the 3.1's are voiced a little hotter than the multiple tweeter array SDA's to begin with, and the Clarity Caps were just too much. The Sonicaps made them much sweeter.
Everyone has their own 'Sound' they're trying to achieve when modifying the SDA's. If you are a 'Last spec of detail' guy, then the Clarity might be for you.
