Help with SAE preamp Mark 1 B
Hello. I have a problem with the CAE Preamp Prevention. Deoxit button handling did not help. I can not find the service manual. can anyone share?jetyo70vxdef.jpg
    audioluvr Posts: 6,014
    Most here consider equalizers as taboo but if you are deadfast on using it then after applying deoxit to a switch turn it on and off about a hundred times to work it in and clean up the contacts.
  • fireserzh
    fireserzh Posts: 22
    I solved my question. thanks to those who helped me. subject can be closed
