High pass 20uf cap.
crashb4
Corrected.
A brief question for the gurus. On a 1986 SRS crossover, which 20uf cap is The shunt on the low pass? New Clarities due tomorrow and I don’t remember which location on the board. Did a search. Don’t seem to find it.
TIA
TIA
Schiit Freya+, Krell KAV-250a, R-Pi network streamer, 8Tb NAS, Thorens TD-145 MKIII with Ortofon 2M red, Polk: Monitor-10B, SDA-1A, SDA-SRS
https://us.v-cdn.net/5021930/uploads/attachments/1/8/5/1/1/26684.pdf
There are no 20uF caps in the high pass
Oops. Thanks. What I am looking for is to ID the 20uf shunt cap in the low end. Sorry for the mix up.Schiit Freya+, Krell KAV-250a, R-Pi network streamer, 8Tb NAS, Thorens TD-145 MKIII with Ortofon 2M red, Polk: Monitor-10B, SDA-1A, SDA-SRS
It's the two per crossover that say "20 uF" on them.Gustard X26 Pro DAC
Understood. One is a shunt and the other is in the signal path. I don’t remember which location on the board is which.Schiit Freya+, Krell KAV-250a, R-Pi network streamer, 8Tb NAS, Thorens TD-145 MKIII with Ortofon 2M red, Polk: Monitor-10B, SDA-1A, SDA-SRS
Follow the tracers on the board. It's the one not linked to the two 130uF caps.Gustard X26 Pro DAC
Both 20uf are shunts. -
The dimensional one is a bypass cap.Gustard X26 Pro DAC
Not according to the posted schematic. The two 2.75mh coils and 20uf caps both form separate low pass filters. One for the stereo woofers and one for the dimensional array woofers.
I'll drink to your shunt if you drink to my bypass...Gustard X26 Pro DAC
Drinks for all. Thanks for setting me strait.Schiit Freya+, Krell KAV-250a, R-Pi network streamer, 8Tb NAS, Thorens TD-145 MKIII with Ortofon 2M red, Polk: Monitor-10B, SDA-1A, SDA-SRS
