7.2.4 setup
I'm doing a 7.2.4 setup in my theater room, I currently have (2) 265RT FL & Fr, 255C-RT C, (4) 65RT surround, (2) DSW Pro 550 speakers. I need help with selecting 4 ceiling speakers for Dolby Atmos setup.
  • mrloren
    mrloren Posts: 2,474
    edited April 2020
    Any will do, I like the MC/VC series. Same speaker but the VC is vanishing and looks a lot better.
    If you can follow the Dolby setup. Front height 1/2 way between the fronts and surrounds. rear height 1/2 between the surrounds and rears.
    Then save up for a pair of HSU VTF3 or SVS PB3000/4000 subs.. might as well make the house shake.
  • TopperDude
    TopperDude Posts: 166
    Go with the 900-RT or 700-RT as a perfect match with the RT range your already picking up.
    On a different note - Go with 3pcs of 265-RT for the Left/Center/Right and mount them vertically. (You will need to use acoustically transparent screen though).
