Dead Battery's
kevhed72
Can I use a 700 CCA battery in my Pilot if the book says use a 550 CCA?
If course....they are out of 550 CCAs....darnitt
Would it even fit?"This may not matter to you, but it does to me for various reasons, many of them illogical or irrational, but the vinyl hobby is not really logical or rational..." - member on Vinyl Engine
As long as the battery is same physical size or will fit in the battery tray, then yes it will work with no problems.
Thanks....so I stuck with the same battery size but supposedly more CCAs (cold cranking amps) is ok or even better.
So I went from 585 to 700 and living large now. -
May your cold starts be quick and vigorous.
