MIT Speaker Cables
I know there is some love on here for MIT Cables with SDA speakers.
I have been looking around for some decent used ones.
I found 3 sets.
L/PC Squared $125
Terminator 2 $200
Terminator 6 $250
Are the Terminators $100 better than the L/PC and if so what is the difference between the T2 and T6 besides 4 ... ?
I have a Butler TDB 2250 Amp, driving upgraded SDA 2.3's if it matters. I'm using a Yamaha CR 2040 as my Preamp for now.
I'm not Dead Set (great album by the way) on MIT but people that know more than I on here seem to really like them.
$250 ish is my budget, but less is always better.
Thanks as always for any input.
  • motorstereo
    motorstereo Posts: 2,380
    My advice would be to save your money and use it towards a good preamp. You won't notice a difference in cabling when using the Yamaha receiver as a preamp.
  • verb
    verb Posts: 10,176
    edited March 2020
    Welcome to CP! I have lot's of MIT cables, started out with the T2's, and eventually upgraded to the Shotgun's. You are correct. Lot's of love here for MIT cables.
    Not sure about the L/PC's never heard of them.
    The T2's from what I read is the sweet spot of the Terminator line.
  • My advice would be to save your money and use it towards a good preamp. You won't notice a difference in cabling when using the Yamaha receiver as a preamp.
    I'm working on that as well. I'm in the process of selling a few pairs of spare speakers to fund a preamp which will be a whole other process... But I can't say the Yamaha sounds bad, the phono stage is really good and it certainly looks great but I figure it probably has some Sonic limitations.
    Staying around $1k for the preamp is my current budget. If anyone has Preamp suggestions please feel free to chime in.
  • verb wrote: »
    The L/PC look more like everyone else's cables without the box. I assume it's probably their lowest level cable but very little info on them on a Google search.
    pitdogg2 Posts: 27,411
    No network box... Pass
  • verb
    verb Posts: 10,176
    edited March 2020
    Oh ok. 2 hundie for the T2's is not a bad price.
    Lot's of choices too for a pre less than $1K! Keep an eye on the FS thread! Always lot's of good stuff! I do most of my shopping there! :smile:
  • motorstereo
    I didn't notice a cabling difference when I used my restored Yamaha C4 pre but I did when I moved up to a Mcintosh C33. The cabling differences were even more evident when I moved up to a 2 piece Mcintosh C100 preamp. I've had a few of the Terminator series and I suggest saving up a bit more and going for the Shotgun series.
