[question] Polk Woodbourne Drivers' model number
Hello, wondering if there are any polk customer service people or otherwise on here who could tell me what the part number is for the main 5.25 inch drivers on the polk woodbourne? The spec sheet says 5.25 inch mid woofer 75W mineral filled dynamic balance polypropelene.
I am trying to buy replacement drivers, or maybe another passive speaker which used this driver, from which I could salvage this part.
I wrote to Polk europe CS but got a reply that they have never stocked this item.
thanks.
MODS: I am not able to amend the post type to be a question
thanks.
Bump ... any Polk customer service folks who could help?
maybe some looking at something like this?
https://cpc.farnell.com/peerless-by-tymphany/fsl-0512r01-08s/pro-5-25-woofer-1-2-vc-8-ohm/dp/LS05131
physical first, electrical and then get the best you can afford. Will need to replace both speakers or else any slight difference would be so noticable.
Really interested in some dismantle photos and inside guts photos if you cna manage it.
thanks -
another one to check out.
https://amazon.co.uk/QTX-Sound-Woofer-Speaker-Driver/dp/B009L3X7IO
Good luck.
